On my 396T I recently ran into the problem of the keypad not working, save the power button. I have searched high and low to find out what is wrong and how to fix it, including opening up the scanner and cleaning the contacts (while also replacing the keypad rubber). I put it all back together and have the same problem. Only the volume/squelch, function, menu and power buttons function. The scanner, outside of the other buttons not working, seems to work just fine. I also tried the func-power on to ensure it was not locked and also checked in FreeScan to make sure the system didnt have protection set to on (as described in other threads).
Does anyone have any idea as to what is wrong? What is the best thing to do about this? Is the scanner essentially only good for program control now via PC?
Thanks in advance for any ideas, pretty sad this 396T that has only been lightly used is completely inoperable. I also have a 996XT and BCT15 which work great, but not portable, so the 396T is my travelling scanner and a shame it doesnt work as such.
