I am new to Uniden 436 scanner , having previously used Radio Shack products for scanning for over 30 years. The question is in regards to selective ID only scanning in a Trunking favorites group. I created the trunking favorites bank with frequencies and ID tags and descriptions using Sentinel and they all transferred to the scanner , but I can only here traffic in the ID Search mode. Not sure how to scan only the desired created ID tags only in the trunking sysyem and not hear all the other non related ID tags.
Many Thanks!!
Make sure that you have the desired Service Types active. When shipped, as well as when you first install Sentinel, only the Dispatch service types are enabled for Public Safety: Law Dispatch, Fire Dispatch, EMS Dispatch, and Multi Dispatch. You also need to enable the
Tac and
Talk service types for these: Law Talk, Fire Tac, EMS Tac, etc,
If you have your Favorites list programmed correctly, and the correct Service Types enabled, but are not hearing anything unless in ID Search mode, then it appears that your scanner is not "seeing" those programmed talkgroups. If you are using Quick Keys, be sure that those keys are enabled.
When working correctly, ID Scan
only scans those TGIDs that are programmed,
and are not set as Avoid individually, and are not in a Department that is set as 'Avoid'.
ID Search stops on any active TGID that is not (a.) set as avoid, and (b.) not in a Department set as Avoid.
If you like, export your Favorites list into an *.hpe file. (That option is under the drop-down File menu in Sentinel.) Note where it is saved on your PC. Using Windows Explorer (called File Explorer in Windows 10), find the exported file & <right><click> on it. From the menu that pops up, select "Send to", then choose the option to send it to a compressed (zipped) folder. Youcan then attach the sipped file to a post & any number of us can take a peek to see if something is amiss.
