Uniden BC23A External Speaker
RalphTomaccio
Slatersville RI
Checked all the forums and am hoping I picked the most appropriate one to post this in. If not, please advise.
I purchased a Uniden BC23A External Speaker in February to use in my Jeep to amplify my CB speaker and is used in off roading. Last Saturday while on a run it was working fine up until mid-day when it just stopped working. For the power source, I tapped into the power going into my CB just after the in-line fuse going to the CB. The CB is still working. Although it looked fine, I then changed the BC23A in-line fuse just before the speaker and it still doesn't work. I tried taking out the fuse and held the wires together that make contact with the ends of the fuse and it still didn't work. I'm down to what I believe are the only two things left.
One is to re-do the electrical connections for the power where I tapped in, thinking it may have lost contact somehow. I did use butt connectors, the proper crimping tool and a heat gun to seal the connections which happen to be behind the glove box. I would be quite surprised if it is the connection, but I will keep all possibilities open.
The second thing is that maybe the speaker itself is defective.
Now, before I cut into the connections or take the speaker out of the Jeep, I wanted to find out if there is anything else I can try before doing so. Your help/suggestions are most appreciated.
scottyhetzel
Palm Springs Area / OrCo
Yes, Next try using a different source.. Like an iPod or something that delivers line level signal.. I do not like fuse holders like glass ones. Not great for mobile installs. Use the ready available atc type fuses. Welcome to RR..
The speaker is not sharing between the CB and scanner correct?
Btw , this is what kind of work I do ....nice marine grade heat shrink.
ofd8001
Louisville, KY
Is it getting audio? I'm thinking that when the speaker "senses" incoming audio, it turns on. So if an audio cable popped loose, it could be an issue.
On the power side, if you have a power tester that sort of looks like an ice pick with a lamp bulb, you can pierce the insulation and see if the power wire is indeed hot, though you may have to use some electrical tape after.
