Uniden BCD325P2 programming Question
bveitch2
The Data base only shows 7 frequencies for the police in my area, no trunked systems. I hear some chatter on the conventional channels (usually on 2 of them), but I know there is more, as some of the other frequencies cut in with noise (sometimes motorboat sound, squelling, etc..) quite often.
I have tried to program the bcd325p2 on p2, MOT both through freescan and manually with no luck, as all I have to go on are the frequencies given.
Any hints on what I should do next?
wtp
Port Charlotte FL
look up the word encryption.
also it could be a digital signal that the radio can not decode.
even if you put in a P-25 trunked voice frequency you will hear it.
unless you are too far away and it can't get enough signal.
ofd8001
Louisville, KY
Be good if you could say what system this is too. That way we can look it up and see what's what.
