The link above is not for the BR330T.
That link is the procedure for tweaking the AGC digital/analog settings for the
BCD396T and
BCD996T.
And those directions do not apply to the 330, its not digital..
This is the procedure for the 330
Adjusting AGC Parameters (Unofficial)
This setting is neither fully tested nor supported by Uniden America Corp.
ATTENTION!
This change allows access to some AGC parameters that might result in poor audio. The default settings of 0 have been arrived at through testing in multiple environments. The use of other settings is at your own risk. Uniden America Corp. is releasing access to these features without support.
General Notes:
• All settings are saved, even when you cycle power and the option is no longer available.
• These settings are not accessible through UASD.
To access these settings:,
1. Press [HOLD] while turning on the scanner.
2. Tune to an analog channel.
3. While receiving a signal, hold F then tap the scroll knob. The scanner displays the current RES TIME parameter setting (see below for option details).
4. Rotate the scroll control to change the setting.
5. F+rotate the scroll to select another setting.
Parameters:
RES TIME
Range: -8 to +8 (0 is default)
This parameter determines how frequently the AGC factor updates. Decreasing this value makes AGC respond faster, but could result in “pumping.” A higher value decreases the response time.
REF GAIN
Range: -5 to +5 (0 is default)
This parameter determines the reference level that AGC attempts to adjust the volume to. If digital/analog volume is not matched, adjust this parameter.
GN RANGE
Range: 0 to 15 (0 is default)
This parameter controls the total dynamic range of the AGC adjustments. A larger value allows a wider variation in volume.
