Liverdog said:
I would like to echo RandyK's comments. I thought I was having scanner issues too since using beta 10. I had been noticing that the voice radio, decoding P25 was only giving me every other transmission on the same TG and channel. Then I noticed that after the first transmission the radio would park on a blank memory channel and not go back to the same TG and channel when a voice response was sent.
Other times, when multiple TG are active on a site the voice scanner will be directed to a frequency and TG, but once that conversation ends, the voice scanner will not be directed to another frequency and TG even though there are many active ones - it will just go to the park channel until the entire site has no activity, then it will start directing the voice scanner again.
Rick, I've looked at this problem at bit more. Let me see if I can explain the problem a bit more.
I have a very good decode rate on the P25 system in question (high 90's). I see all the activity that I expect in the UT screen (i.e. dispatch makes a call, unit responds, dispatch calls again, unit responds, etc). However, when the voice scanner is being commanded, it is only commanded to the correct frequency/TG every other transmission. So, if dispatch calls first, I hear dispatch as the voice scanner is commanded to the correct frequency. However, as soon as the unit being called responds (same voice channel) the voice scanner automatically goes to the "park" channel and sits there until dispatch keys up again, then it goes back to the correct frequency. This occurs very fast, just as if:
Disp: "3A31 copy AOA"
3A31: "go ahead"
Disp: "3A31 respond to..."
In this example, all I hear is the dispatcher, not 3A31.
The opposite is true too, just in case you're thinking I've locked out everything but dispatch. If the unit starts first, then dispatch, then the unit, all I hear is the unit. The voice scanner is commanded to the park channel for every other transmission.
The voice scanner in this case is a BC250d.
This problem is very repeatable. The only time it works correctly is if the responding party waits long enough that the channel drops and then UT picks it up when the responding party's channel is assigned a frequency at a later time.
