I'm looking for some information or assistance on getting UniTrunker to work with an Icom PCR100. The last mention I can find of this configuration was in a short thread over a year ago, someone was having troubles and there didn't seem to be much of a resolution.
The PCR100s are attached to an XP SP3 laptop (1.6gHz P4/1gb RAM). The radios work great with the stock Icom software, and all the flavors of 3rd party interface software. The local control channel broadcast comes booming in.
However, when try to set up the PCR100, it just doesn't seem to work. After setting up the receiver, Unitrunker will turn on the PCR100, but I've got a feeling it's not changing the receive frequency. Also, the volume control seems very flaky. Most of the time, I can barely hear the audio coming out of the speaker, so I end up listening to the discriminator output through the laptop speakers. If I make adjustments to the volume several times, eventually it seems to "catch", and I can hear it until I stop the receiver. Then the process starts over.
If it's simply reached the point where the OS and the radios are just too old to be supported, so be it. But if that's the case, I'd like to confirm that before I spend a bunch more time on it. Or if someone has this arrangement working, I'd appreciate the help.
I've had good results running UniTrunker with a pair of RTL-SDR dongles, so at least at its most basic I understand how to set it up. It just doesn't seem to like the PCR100s.
Thanks in advance,
Scott KC9LQV
Thanks in advance,
Scott KC9LQV
