UniTrunker Error Message
tbogs
Helper, UT
At the top of the screen where it should say site name...control signal strength, etc... I get this message: ERROR (Use Receiver menu to re-configure for recording). I'm using a PSR-600 via PC/IF and everything is decoding good...just trying to figure out if anyone else has had this problem and how to get rid of this error message at the top of the screen.
Look under [R]eceivers. Make sure the Signal Input is "null device". Set the Voice Radio to "PSR600". If that does not work, try "PSR500". Both models behave the same so really either should work.
tbogs
Helper, UT
Had Voice Radio to PSR 600 and that was causing the error message...switched to PSR 500 and that fixed the problem. Easy enough...thanks!
