UniTrunker first public beta
I tried to put this in the Wiki but it didn't work.
Turns out the forum doesnt like MSI files either. Rename the file so that the file ends with ".MSI" instead of ".ZIP". After that you can run the installer.
Warning - this is not for the faint of heart. Back up your data and have fun.
-rick
Joseph11
Very buggy, but thanks for the release. I need to read the documentation.
ssmith39
Fallbrook, CA
It's working - using a PCR 1000
Rick,
Thanks for your efforts. Let me know if I can be of assistance.
For info: Radio is a PCR1000, using XP SP2 on a 2.5Ghz Dell with 768 ram.
JohnnyGalaga
Thanks for the release!
How do I configure the signal to use a slicer via COM1 ?
Joseph11
The documentation doesn't say how configure Uni-Trunker for UHF systems. How do I tell it the base frequency, offset, and step size?
EDIT: Nevermind, I found it.
jlh
Thanks Rick, glad I was unable to sleep now. Particulary like the Subscriber list so far.
Joe
jlh
I have Universal Trunker, MTrunker, and T4Win all running on the same box at the same time, all 3 working fine.
Joe
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
THANK YOU rfmobile for this software! Working splendidly here on the Smartzone system. Once I figure it out I'll get another copy going on the MPT1327 system.
Everybody who has been on Rick for the past few months in the "ETA" thread and others needs to thank him for this product!
MattSR
Sydney, Australia
Thanks Rick!
Im running Mtrunker32 and Unitrunker at the same time, but only Mtrunker is decoding (from a mic input) Unitrunker just shows the menu, but with no decoding info...
Cheers,
Matt
MattSR
Sydney, Australia
The doco says that you just need to run the program, but I discovered that by default, the decoder is set to Offline...
Cheers,
Matt
RolnCode3
Sacramento/Bay Area, CA
Thank you gentlemen who've worked diligently on this! We applaud and appreciate your efforts!
Enough brown nosing. . . good job and thanks. Eagerly awaiting the future releases.
W4KRR
Coconut Creek
When I tried to unzip, it says "The compressed (zipped) folder is invalid or corrupted".
Joseph11
It helps to read the first post.
-rick
JohnnyGalaga
Has anyone gotten it to work with a slicer and a serial port? I have WindowsME and can run.Mtrunker just fine. After starting UniTrunker, I go to options, set the decoder to Online, then I've gone to Configure Signal which brings me to the next menu where the fields are labled in red.
The Signal Input field is blank, and pressing the space bar or the arrow keys doesn't do anything. :roll:
Is there a way to make the program work off of COM port 1, or am I doing something wrong?
Thanks!
scannerfreak
Well Known Member
Indiana
Thanks!
Ya I can't get it to work either with my slicer and COM-1, and XP..I know all my settings are right to( (DSR Pin COM-1,Invert off, Decoder online, Baud setting are correct as well) I was able to change it from sound card to DSR just fine by arrowing up and down..Just make sure your slicer is plugged into your COM port before you start the program up.... Trunker works fine..Oh well, I'm probally doing something wrong :(
JohnnyGalaga
Where did you go to change it from sound card to DSR?
One of the DOCS says something about installing some sort of a driver to make your serial port work on XP.
scannerfreak
Well Known Member
Indiana
Go to [O]ptions, [C]onfigure, Use up and down arrows to change the signal input
FPO703
Planet Earth
I tried to install this package on my WIN95 system and was greeted by a 'this is not a valid file type'
:evil:
james32746
Lake Mary, FL
problem solved and program was sucessfully downloaded using Netscape 8.0 instead of Internet Explorer
Jay911
james32746 said:
I can't download it, it will not download the file but instead it will come up with the download screen for "modules.php" which apparently is not the intended file.
If your system uses a download manager such as GetRight, you may see this type of message. I just let it run and GetRight eventually downloaded the proper file.
