I have been unable to find a location to change the font color away from this lime green. Any suggestions? Thanks in advance.
These are, of course, radio IDs. Double-click on any one of them to see the corresponding window appear. Click the info tab and change the color there.I have been unable to find a location to change the font color away from this lime green.
So, there's no way to change the default color away from lime green other than individually changing the colors???These are, of course, radio IDs. Double-click on any one of them to see the corresponding window appear. Click the info tab and change the color there.
You can also open the system window (click the "home" icon), select the Users tab, click on the desired radio ID and press F2 to place the grid in edit mode.
You can edit the color by typing in the RGB (red, green, blue) values or click the drop-down arrow to the right of the edit box. A pop-up color palette will appear. Pick your color.
You can use the multi-select feature to select multiple items and change the color all at once. You don't have to edit each item individually. However, newly discovered groups / radios will appear in green. There is a mechanism to control the initially assigned color / text label / listen priority but the program's user interface does not yet make this available.So, there's no way to change the default color away from lime green other than individually changing the colors???
