Unitrunker help for FleetNet Zone 2
Ontario, Canada
We finally got Unitrunker to pick up the control channel at Site 10 (Harrowsmith Tower) - We have the control channel set to 142.260.
We're picking up the Romeo (Frontenac) units with no issues, from Dispatch and Officers.
The problem we're running into is the Juliet (Lennox and Addington) units are having minor issues. Dispatch is coming through, but the units are not returning according to Unitrunker. We know that they're responding as we can hear it on the repeater channel (413.5375).
In Unitrunker we have the following frequencies listed, 142.485, 141.930, 141.720, 142.995, 142.395, 142.260, 141.540, 142.590, 142.095, and 142.185.
We're local to Lennox and Addington, and are trying to figure out what we're missing.
mciupa
Canadian DB Admin
Moderator
I'm here a lot
I don't see 142.485 and 142.185 listed for the Harrowsmith site. Do you see any Napanee talkgroups pop up at all? Try programming Denbigh Site 15 and see what happens.
010 (A)Harrowsmith (HARROW)Frontenac141.540141.720141.930142.095142.260c142.395142.590c
142.995
011 (B)Mountain Grove (MTNGRV)Frontenac141.360142.170142.245c142.455142.845
012 (C)Mount St Patrick (MTSPAT)Renfrew141.195141.495141.555142.650c142.920143.145c
013 (D)Pembroke (PEMBRK)Renfrew141.435141.675142.125142.380c142.710c142.950143.970
014 (E)Demorestville (DEMOVL)Prince Edward141.195141.435141.690142.320142.515c142.620c142.740
142.980
015 (F)Denbigh (DENBIH)Lennox and Addington141.390141.705c142.230c142.335142.545142.890
Ontario, Canada
142.995
142.980
We've now attempted to pick up the Denbigh Tower, but the control channels do not pick anything up. Unless the control channels have changed, which I doubt, but they don't appear to be good for us.
Ontario, Canada
Base - 141.01500
Lo - 380
Hi - 6
Spacing - 15.000
Slots - 1
You will require this for it to function properly. Probably a chunk of your issue. You may need to nuke the existing LCNs with 00's that probably populated.
Would you be okay if I sent you a message?, you seem to know what you're doing compared to us.
Enjoi19
Ontario, Canada
Feel free to continue the questions on this thread as I may respond slowly and others can jump in if possible.
Aviator747
Cornwall, ON
I am using UT2.2.0.26
I do not have anything under band plan. I set my signal vfo to 142.260 "site 02", it pulls in LCN's. I take the LCN number and go here: Fleetnet inputs wanted I find the LCN number on the list and then take the frequency beside it and enter it into the frequency spot when clicking on the LCN number in UT. I then listen away. I use one sdr dongle with two vfo's.
jets1961
So can someone tell me what system is active out here in Prince Edward County, the old FleetNet or the new Phase II system (or both)?
