So I'm trying to make this work with the local EDACS system, and I'm running into problems getting Unitrunker to actually do anything at all. I'm using the latest version of SDR# with a couple of RTL sticks, the latest trunking plugin, dsd160, and the latest version of Unitrunker.
Everything is seemingly set up correctly and I get a good signal. When I start Unitrunker sometimes the site window will pop up and it will track the system for anywhere from a few seconds to a couple of minutes, but it will always just stop doing doing anything after no more than a few minutes have elapsed.
When it does work for these brief moments, everything works, properly controlling SDR# and I get good audio through DSD. Then Unitrunker just ups and dies on me. Sometimes if I close and reopen it, it will work for another few seconds to a couple of minutes, but more often than not, it continues to do nothing.
Everything else in the chain seems to be working, I just can't get Unitrunker to do its part. With Unitrunker out of the loop, I can click around the waterfall in SDR# when I see transmissions and I get great audio through DSD, I just need Unitrunker to work.
The system I'm trying to track is Albuquerque / Bernalillo County Trunking System, Albuquerque, New Mexico - Scanner Frequencies
