Good afternoon gang!
Note to mod. If this isn’t the correct forum to post this issue, Please let me know and I’ll remove and repost in the correct forum…I’m thinking as far as I remember, this is my first post to RR.
Not totally a newbie, been using radiofeed (web server) with Unitrunker so That “I” could listen to our P25 system while away from the house.
Been working great for about a year. This morning, Attempted to start Uni and got the error window pop up and said need to update uni to a newer release. I did. Since then, Unitrunker 2.1.0.38 works fine, Radiofeed “looks” fine BUT get an error message (below):
Unable To Open Web Server Input Sound Device
Reason: Undefined external error.
Input Desc: Primary Sound Capture Device
Input ID: -1
Channels: Mono
Samples Per Sec: 44100
Go to the Windows Mixer and verify the input is enabled and plugged in
No matter what input I select, It errors……. Only thing I changed was upgrading Uni…Everything “was” working fine until the Uni Updated to 2.1.0.38, the original uni working was 2.1.0.24.
Unitrunker is working, Hearing and decoding fine. Radiofeed is loading fine, just that radiofeed cannot “hear” unitrunker.
Windows 10 laptop. Again, it was working fine until I upgraded Uni. As far as I know I’ve not changed anything else on this machine.
Anything I can tell you in the group, that might help one of you help me?
I appreciate any help.
Thank you,
Rob
WA4IPE
Input ID: -1
Channels: Mono
Thank you,
Rob
WA4IPE
