neonhomer
I am using a Pro95 and the latest Unitrunker. I checked to make sure I am getting good audio through UniScope. However, Unitrunker keeps telling me "No Signal". I am trying to scan EDACS.
I have the scanner plugged into the mic in jack on the sound card, and I am using the headphone jack on the scanner. I turn the scanner on, and adjust the volume so it is not clipping in UniScope. I tune to the control channel. The scanner display shows the different groups that it is decoding.
Using a SB Audigy and Windows XP Pro SP2. I know I have the source configured right because I can select the mic monitor and hear the control channel.
Config from Options:
Auto Save Off
Display Mode Decimal
Signal is Auto
Decoder is Online
Logging is Off
APCO P25 is ON
Recievers
Signal Input Default Sound Device
Sample Rate 44100
Sample Bits 16
Voice Radio none
What am I doing wrong?
Auto Save Off
Signal is Auto
Decoder is Online
Logging is Off
APCO P25 is ON
Recievers
Sample Rate 44100
Sample Bits 16
Voice Radio none
