Unity XG-100P questions
TDR-94
Not sure what GE Star change your talking about (I don't recall saying anything to you about such a thing, but I digress). But, for the button options the change doesn't require firmware change on the radio. This hack is hack to RPM (the programming software).
He has you confused with another member on the forum, who was instructing him how to enable GE STAR, in RPM, for the XG-100P.
mancow
N.E. Kansas
How are features upgrades loaded? Is it file that is loaded in somehow? Where in the software is the menu for that?
TDR-94
Features are enabled via an encrypted file called a feature string. The feature string file is created by L3HARRIS TAC, after requesting features from an L3HARRIS dealer. The file is then sent to you from the dealer and you then load the file, using the separate Radio Maintenance utility that comes with RPM.
mancow
N.E. Kansas
That makes more sense. Thanks.
rjschilder
AES FTW
Just for the record, XG100p uses the feature string (via RadioMaint) to update features. The encrypted XML file you're referring to is for the XL line of radios, which is loaded via RPM2.
IFRIED91
Arrive alive
NYC area
You can convert an RPM14 mission plan for easier editing (ONLY works good with Microsoft excel)
IFRIED91
Arrive alive
NYC area
Sets converter
Right under it…The help section in RPM is pretty helpful tho
Radioman96p71
Sets converter in RPM has nothing to do with CSV files. RPM2 supports import/export of CSV files.
The help section in RPM is helpful for understanding what functions do.
