Unknown Capacity Plus system Broward County area
W4KRR
Coconut Creek
I'm trying to identify a Capacity Plus trunked system being heard in the Broward County area.
Per the DSD Plus program, it has 6 LCN's. LCN's 1 and 2 are unknown, 461.750 is LCN's 3 and 4; and LCN's 5 and 6 are unknown. Color code is 1. Talkgroups logged are 14, and 150 through 158, and a few others. Most of the traffic sounds like a hotel; also "runners" and a pro shop were mentioned.
Suntalk is licensed to use 461.750, and they seem to be the likely system, but this system is not in the RR database, at least for Miami-Dade, Broward, and Palm Beach counties, and it is unlikely I would be able to hear anything further away.
TampaTyron
Beep Boop, Beep Boop
Phoenix, AZ
SunTalk does not run Cap Plus that I am aware of. They are Connect Plus. Sounds like a hotel with a golf course. TT
ecps92
Taxachusetts
Don't forget search the FCC, many users may not have updated the license for DMR or even from Conventional to Trunk - so don't rule them out, but use the License to see if you get the same Color Code on the other licensed Repeaters.
One quick search of licenses, shows the Breakers if looking for a Hotel/Resort
W4KRR
Coconut Creek
Pretty sure it's not Northwest Regional Hospital . They use 462.1125 as a stand alone repeater with a different color code; I haven't heard anything on 451.950 at all.
CanesFan95
Was Homeboys-Scanna
FL
Tune conventionally for the CW ID, and use recording software so you can play it back. Then look up the callsign.
rhinosmirk
Margate, Florida
Hello, K8mem here in Margate. Was just wondering if you know how to put the frequencies in the Dsd file so I can track broward fleet service using nexedge48 and a CC of 471.900, been trying for a few days but got something wrong. Maybe you have a sample line I can go by. Thanks
W4KRR
Coconut Creek
Do you mean the Florida Fleet Talk NXDN system? If so, the attached file works for me. The name of the file must be "DSDPlus.frequencies".
  • DSDPlus.zip
rhinosmirk
Margate, Florida
Thank you so much being new at this I would have never figured those lines out. One question if I may ask, I use an RTL with just Fmp24-cc and 1r. I noticed that when trunking Ft Lauderdale I only hear dispatch and a couple of other TG’s Where’s the few dozen others? Is It because the RTL is filtered and blocks them? Thanks again 73’s
rhinosmirk
Margate, Florida
I’m talking about the 800mhz police
W4KRR
Coconut Creek
Nothing is blocked. It could just be a period when the other talkgroups aren't being used.
