BCD325P2/BCD996P2: Update fail
Golay
Nankin Township Michigan
The attached snippet is what I get when I try to update my 325.
Current firmware version 1.08.01.
Using Freescan to program thru Radio Reference works just fine. I'm using the same cable as I program the radio with.
Any suggestions? Thanks.
tvengr
Well Known Member
Baltimore County, MD
Give it a try again at a later time. Sometimes, the servers are down for maintenance. Which cable are you using? Is it the Uniden cable that comes with the scanner? Some cables will not work for firmware updates. If another cable, please post a link to the cable.
Golay
This is the cable I bought. Off Amazon. May be the issue. Didn't get a cable when I bought it used. Like I said, works fine for programming with Freescan. As far as day and time to try, I've tried it at least a half dozen times in a two month period since I bought the radio.
tvengr
Well Known Member
Who is your internet service provider? There are several problems with providers. T-Mobile blocks FTP ports and HughesNet has high latency.
BinaryMode
Banned
2600 dialtone blvd
This is why it is massively stupid how Uniden made the update process. Before you could download the firmware update. Now you need an interaction with a stupid application.
It's especially annoying to have to use the update application in a car. You either better make sure your home Wi-Fi reaches or you use a tethered cellphone with your laptop. And not all cell phone providers allow tethering. To those that use such a provider I pity your soul.
garys
Central Texas
He didn't write his post particularly well, but he said that he used Freescan to program the scanner without issue. I think he was just trying to say that the computer could communicate with the scanner.
Back to the OP. I had a problem with my ISP blocking the port used download the firmware. I ended up using the hotspot on my phone to perform the firmware update.
That is what the OP said
garys
Central Texas
Why tether when you can use the hotspot on your Smart Phone?
garys
Central Texas
Okay, you got me. I didn't know that was possible. Not that it really matters because for the SDS200 in my truck I just pop out the SD card load the firmware onto it and start up the scanner.
And several members here have no idea how to update firmware in x36's and SDS's scanners without using Sentinal.
The Uniden software makes it easy for users to update firmware in their scanners.
BinaryMode
Banned
2600 dialtone blvd
That's what I was referring to...
Anyone know if Uniden actually uses a checksum to verify the download before writing? If you have a bad Internet connection that could pose a problem. Bad firmware flash and radio goes kaput.
