iMONITOR
Silent Key
A UPS is not very efficient and nothing is a clean as true 12VDC from a battery.
APC Replacement Battery Cartridge #162 - APC USA 69.99$/each + tax & takes two...
new apc ups at sam’s club 149$ + tax or 9 bucks more and smidge of payment goes into the kitty to pay membership renewal!
Olde unit to the local dump no recyle fee...
Looks to be two UB-1280 (12v 8AH batteries) wired in series. $23.95 each (12V 8Ah Sealed Lead Acid Battery w/ F2 Terminals). You can probably remove and reuse the top part that wires the two batteries in series to help it fit properly in your unit.
FYI, since the batteries contain a significant amount of lead it's illegal to simply dump them into a landfill. Will you get caught, probably not, but if you do they really take things like that seriously since they're classified as hazardous materials with both state and federal laws controlling their disposal.
I have been using 2-12V deep cycle batteries in parallel for about 10 years for constant power for radio's and also a 16 channel DVR for security cameras, and also powering 6 cameras with IR for night vision.
Sorry this was so wordy but it brought back old memories both good & bad!!
I'm using a 25 year old UPS that came with the wife when we got married.
But yeah, even the newer gel cell systems require a lot of respect when working around them. Those $1,500 insulated tool sets suddenly look like a really good deal. Mistakes get messy really fast.
You need to tell her that she came very well equippedI'd love to know her reaction when you tell her you said that over the internet.
If I understand the situation properly, a lot of the battery and solar things (cars etc) are going to 300+ volts. We are all going to have to start thinking about higher voltage DC again and adjust how we do things.
(network guys are scared of electricity and want everything to plug in).
Thats good stuff!
Some solar system are, works a bit better for converting to 110vac.
The high voltage also has much lower losses. I looked at a West Marine Catalog about wiring losses and 12v losses are enormous over even short distances. I thought about it wen trying (just thinking really) about wind power. Even the short distance down the mast from a 12 vdc generator looses a lot of energy, even 48 volts is too low. I read somewhere that "high Voltage" is even being re-defined so that higher voltage DC circuits can be used easier, and in more circumstances.
There is talk, (maybe even a plan), to run some extremely high voltage DC lines as a backbone across the country to help distribute power (which I didn't think was possible).
The losses are the same, voltage doesn't matter, current level does. Running a device off 12 volts is going to require more current than a similar device designed to run off higher voltage.
Interesting info on the long existing long DC lines.
en.wikipedia.org
en.wikipedia.org
en.wikipedia.org
