USB Bridge IC failure
pyeman99
Cornwall UK
We are not talking the USB socket. The chip IC2 located on the front control panel/Board.
Mine failed,which was my own fault, Unplugged power while USB plugged in.
I used a guy that had used before that specialises in SMD repair.
There are 2 chips fitted the number depends on whether your radio has a early or later board.
Early radio's use a CP2104 Later radio's us CP2102N Just make sure you buy a 24 pin device NOT 20 or 28
Hope this helps somebody one day.
JDKelley
Just call me "Sparks." Or "Lucky."
Hammerspace
You may want to ask your guy if he's willing to do mail-order work, in case someone can't find a local guy. I did that with the guy that used to do my alternators and starters (until he keeled over one fine day at 48 - cardiac.)
pyeman99
Cornwall UK
This is UK I took the board out & sent it with the new CP2012N back in 3 days £45
JDKelley
Hammerspace
Oh - right. I should have looked. Still, for the potential benefit of our mates across the pond. . .
Just something to chew on - some of us have resources that the others don't, and if they're willing to be shared, it can be quite a service, don't you know. . .
