zoloff9
I have ordered and searched for a patch cable to hook up my Uniden bearcat bct 15x to the computer to download the freq. been on backorder from the factory outlet. would anyone on here know where to get one.
The USB-1?I have ordered and searched for a patch cable to hook up my Uniden bearcat bct 15x to the computer to download the freq. been on backorder from the factory outlet. would anyone on here know where to get one.
I wished all scanner radios went back to using RS-232 serial ports! They just worked, no drivers required. No lost, disconnected ports.
got it ordered today, thank you all who responded. hope it works,The USB-1?
Indicates as in stock at ScannerMaster.
Uniden USB-1 Programming Cable (BC246/396/330/230/95/996/15/XT)
Uniden USB Cable - Programming cable for the following scanner: BCT15, BCT15X, BC95XLT, SC230, BC246T, BR330, BC346XT, BCD396T, BCD396XT. BCD996T, and BCD996XTwww.scannermaster.com
Several sellers on Amazon also indicate as in stock.
You want them to go back to a 60 y/o standard with ports that aren't carried on modern computers due to size constraints, and well..progress?I wished all scanner radios went back to using RS-232 serial ports! They just worked, no drivers required. No lost, disconnected ports.
The reason they use them is they are now specialized niche hardware for (legacy) hardware, which some of us use every day.Yes! They just work, no problems. Dell currenty still sells professional workstation PC's with serial RS232 port PCI interface cards. Professional lab and test instruments still use serial ports. There is a reason for that.
