USB SETTINGS.
se
Minto, New Brunswick Canada
Hello All.
Can anyone please telll me where in Windows 7 Home Premium the USB Port settings are? And I also have a question about my ASUS R500A laptop computer. If I have forgotten my Windows Logpn password, Is it easy to change my password?
Thanks Sheldon.
CapStar362
GA, USA!
not understanding the question fully?
just to answer though, START > "RIGHT CLICK" Computer > PROPERTIES > DEVICE MANAGER > Universal Serial Bus Controllers
if you want to change your PW in windows, you have to be IN windows...... unless you made a PW Reset file on a USB Drive or CD.....
now, if your techie enough , grab the program called UBCD 4, create a Ultimate Boot CD 4, and carefully use the "Offline NT Registry and Password Editor"
CAREFULLY!!!
read each step carefully and thoroughly!!
it is in full text only, no pictures, no clicking, all command prompt based.
Meskoman
Boot off the Windows disk and select the “Repair your computer” option from the lower left-hand corner
Follow through until you get to the option to open the Command Prompt, which you’ll want to select.
At the Command Prompt type: net user <username> <new password>
Done this many of times!
se
HI.
Hi.
Is the decimal point on the keypad directly on the left side of the '0' key on the keypad? I pressed it and it does not put the scanner into either Mass Storage nor Serial Mode?
Thanks Sheldon.
se
I hope I don't get too much flack for this but when I try to update the firmware for my BCD536HP nothing happens. I have the scanner connected to my 32 bit desktop pc, running Windows 7 Home Premium via the stock USB cable. I personally think that the USB cable is damaged because my wireless keyboard/mouse combo works on the same computer in all of the USB ports. Would anybody who is in the know please offer any suggestions to me?
Thanks Sheldon.
