Use of 430-440 MHz by AST Space Mobile constellation
N5ZKK
AmSat UK and Libre Space are sending up the red flag regarding AST BlueBird Satellites operating in the 430-440 MHz range. Already five of these satellites have just started operation and are broadcasting telemetry. They are planning to launch a further 243 satellites also using 430-440 MHz and in February submitted a request to the FCC Space Bureau for use of the amateur band worldwide
You can submit an Express Comment on Proceeding 25-201 at
https://www.fcc.gov/ecfs/filings/express?proceeding[name]=25-201
AK9R
Central Indiana
The relevant pages from the FCC spectrum allocation chart:
...snip...
...snip.
The precedence of Radiolocation over Amateur Radio is written in the ITU frequency allocations.
GlobalNorth
Fort Misery
The 'PAVE PAWS' early warning system also operates in that UHF band.
Early warning of ICBM/SLBM attacks from the Pacific is far more critical than my use of the 70cm band and yes, I do use it.
prcguy
No its not. I have a lot of $$ invested in my 70cm stuff and ICBMs can take a back seat. Don't make me call Vladimir or Kim Jong. I'll do it....
N4DES
Retired 0598 Czar ÆS Ø
South FL
According to the submittals the use would be for secondary/back-up tracking, and telecommand (TT&C) operations in the band during launch and should the primary links become inoperable. And like what was previously mentioned, amateur radio is a secondary user in this band, so I expect this to be quite a dialog. Overall, this was a very interesting read.
Normally, AST SpaceMobile will utilize the satellites’ feederlink frequencies in the Q-/V bands (around 50 GHz and 40 GHz) for its nominal TT&C functions, however, during Launch and Early Orbit Phase (“LEOP”) operations, as well as when required during emergency situations, the satellites will use either UHF 400 MHz or S-band (2 GHz) Space Operations service bands. This capability is essential in cases where satellites cannot be controlled through the high-gain Q-/V-band satellite antennas.
AST's application. https://www.fcc.gov/ecfs/document/106201991509823/1
TT&C beacons: As noted in the Orbital Debris Assessment Report (“ODAR”), immediately following release from the launch vehicle, the proposed satellites will broadcast a beacon signal allowing for identification and tracking of the spacecraft.3 Specifically, each proposed satellite temporarily will transmit telemetry/tracking beacon signals to authorized non-U.S. earth stations on UHF-band frequencies at 430-440 MHz and S-band frequencies at 2200-2290 MHz under the following limited circumstances: (i) during the satellite’s launch and early-orbit phase operations; and (ii) in an unlikely event of an emergency after the satellite has reached its operational altitude. Under either of those circumstances and subject to coordination with federal government and other authorized operations in the relevant frequency band, the satellite temporarily will transmit, on average: (i) a UHF-band beacon signal, with a maximum bandwidth of 50 kHz, every 8 seconds; and (ii) three S-band beacon signals, with a maximum bandwidth of 0.5 MHz, every 10 seconds. These UHF- and S-band beacons will operate with right- and left-hand circular polarizations, as well as peak antenna gains of 0.0 dBi and 6.0 dBi, respectively, in compliance with the Commission’s requirements for attenuating mean power of emissions and out-of-band emissions.4 Additionally, these beacons will shut off within 24 hours after launch of the satellite or commencement of beacon transmissions during an emergency.
prcguy
Some of these beacons, especially lower frequency ones are used for tracking the spacecraft during launch and placement into their designated orbit then the beacons are shut off. If that's the case here its not a big deal and would probably not impact terrestrial users. However, if these beacons in the amateur and commercial bands are permanent then expect to hear them on the ground as they pass by.
vagrant
ker-muhj-uhn
California
We use 1.25m and 23cm north of the grapevine. I do not have 23cm equipment myself, but other operators do. We have 1.25m and 33cm repeaters as well, which I do actually use. I will say those bands are not as active as frequencies below, in particular the simplex and call freqs.
The 220 MHz and up ARRL contest is in August. Give it a whirl, or just monitor.
