USFS Freqs
eyes00only
Denver Colorado
There are MANY. I would suggest searching 168.00 to 170.00 and
122.00 to 124.00 for air.
8) :shock: :lol:
CCHLLM
169.900 CSQ simplex according to the radios I've programmed for cooperator (mutual aid) use.
eyes00only
Denver Colorado
Ethan
That's a good base list, but as Jeff's post shows, it varies A LOT.
My seach idea works best, if you have the search option.
Jerry :roll: :wink: 8)
radioactive69
Fresno calif.
ADD these to the national cache
USFS Tacs:
173.9125 NIFC T4
173.9625 NIFC T5
173.9875 NIFC T6
166.725 NIFC T7
166.775 NIFC T8
163.487 NIFC T9
Other names may be tagged to these freq.
Doug.
beerzkool
Scanning the Pajarito Plateau since 1995.
Los Alamos, New Mexico
Hi,
The only problem with searching is that you can miss conversations. If you have a modern day scanner there should be plenty of room to put in 48 well established frequencies.
9 out of 10 times the tatical, command, air to ground, and logistics will be these frequencies used at a type I incident.
The air to air changes frequently and sometimes others are ordered up to avoid interference.
The "Guard" and "Flight Following" are nationwide. These are great to monitor to learn new frequencies for a fire from the pilots.
Another resource is the "Mobilization Guide" for your area. Frequencies are located in ch.50 "directory" and sometimes ch.70 "equipment".
