I live in Colorado and I would like to do some control channel monitoring of the state DTRS system, but my 396 currently does not have a discriminator tap. I do however have a BR330T that sits mostly idle on my desk. I was thinking that I could use it to tune to the particular CC frequencies that I would like to monitor, and then feed the audio into my PC and decode the stream using Unitrunker. Can I do it like this?
Here is what I've tried so far:
I can tune to a control channel (853.3125, CO DTRS site 326 in this case), and I can hear audio that sounds like a data stream. I have an audio cable from the headphone output of the scanner plugged into the mic input on my sound card. I then used the oscilliscope feature in Unitrunker, and I'm getting what looks like a clean signal after adjusting all of the levels (no clipping and a smooth waveform). The problem is that nothing is showing up in the log.
Looking through the documentation it suggests using a "small buffer amplifier" between the radio and the PC. Are we talking about, say, running the audio into a home stereo amp, then into the PC?
-- B
-- B
