Using DTMF to signal audio issues
I have run into what seems to be an issue i cannot solve. I have a dtmf decoder that triggers an audio to play over the repeater when keyed. I have ran into an issue where i cannot talk over that audio anymore. It randomly just stopped letting me talk over and i was wondering if anyone had a clue as to what could be going on.
ramal121
Lots and lots of watts
Calif Whine Country
Repeaters can have PTT priority. Depending which source is keying the radio one can preempt another if both are active. Where is your audio generator connected to the repeater? What model repeater?
the repeater is a tkr-850, the 25 pin on the back has a power on pin 16 transmit audio is on pin 9 and the ground is on pin 19. 19 goes to the ground on the amplifier and 9 goes in the positive side on the amp ( running in mono) then 16 goes into the audioboard
I assume that when the dtmf is keyed on a moblie radio it sends that signal to the repeater and the audioboard picks that up and goes back to the repeater to transmit the audio over all the moblie radios. This is a blasting tone for a mine and we need to be able to talk over the tone incase of an emergency etc
