Using NXU-2A to create an IP front end for NX-700
sburns1967
Seeking information regarding configuration required for communication between NXU-2A and Kenwood NX-700 mobile radio. Use case = NXU-2A is an IP front end for a Kenwood radio. Have software that will interface with NXU-2A to key up radio channel. Only single NXU-2A required.
Current issue = it appears there is no communication between NXU-2A and NX-700.
Purchased connection cable from JPS. So I do not believe that to be the issue.
Configuration of the NXU. Used same config to connect to another radio model. Is there a parameter that is required to change for an NX-700 environment?
77702
Is there any programming in the NX-700 required to communicate through the ACC (DB25) port?
Any recommendations are welcome.
Yes, you need to set up the audio input and PTT on the NX-700.
Under the "Extended Function" page….
On the AUX tab, you need to assign your PTT function to one of the I/O ports. Which one will depend on how the radio to NXU2A cable is set up.
On the Modulation Line tab, you'll need to MI2 or DI line, depending on your setup. Switch it from "disconnect" (default) to connect.
kd4efm
EL98 Florida
Are you using the adapter to go between the NXU and the supplied cable? if you did not install that it will not work.
I have this setup, and you have to use all the supplied parts that came in the box.
EXT FUNC>, AUX TAB;
pin 4, output, COR, HIGH
pin 13, input, ext ptt VOICE
sburns1967
Thanks for the replies!
Yes I am using the serial cable supplied by JPS with the adapter. You can see the attached cable pin-out. I have not verified which pins the adapter is "crossing".
I will look into the suggested radio configuration.
@kd4efm Are there default settings you can recommend for the NXU config?
sburns1967
Edit above (apparently there is a 5 min windows that I missed)
You can see the attached cable pin-out. Based on the documentation pin 6 = MI2 (MIC Signal Input).
kd4efm
EL98 Florida
not really, contact JPS Tech support, I will be working on AvTech units Friday with outpost units.
Using JPS voting reciever to mash all the way-points and CP's for a local railroad.
Outpost to JPS, JPS to remote sites, with NXU's.
I will see what we have for settings and let you know.
kd4efm
EL98 Florida
By the way, follow the paper, even though it says TKx180 series, follow the guide and you will come out okay.
