I am using the Whistler TRX-1 with PRO96Com. The operating manual that I have doesn't describe support for the TRX-1, yet it does seem to work. But I have two issues:
1. When I run PRO96Com on a strong nearby P25 system, which is already programmed into the TRX-1, the "Decode Information: Receive Rate" indicator jumps up and down from 0% to 100% decode, even though the bar graph on the scanner stays consistently at five full bars. Of course, at 0% decode rate, the program doesn't decode anything.
2. I created a scan list with just the control channel and all alternates for the system in question. The scanner stops on the active control channel, five full bars, seems to be working, but PRO96Com doesn't detect any signal present. Why isn't it seeing the control channel?
