USPS LTR in West Milwaukee
jawhite2
Since when is the USPS using frequencies in the 800 Mhz range?
854.7625 has the callsign WQCG671 according to FCC records.
The FCC does not license federal government agencies.
What is going on?
Regards,
John
pfish
What makes you think USPS uses it? It's registered to: DRAGOTTA, JOSEPH G. LTR is sometimes used for businesses, which is what it looks like in this case. He probably set up an LTR system and sells the talkgroups to different businesses.
JGP
Franklin, Wisconsin
What is going on?
Regards,
John
John,
Do you have the LCN for 854.7625 and the other frequencies to go with the license? I live in Franklin and should be able to receive this.
Joel
jawhite2
I said it is a USPS system because whoever submitted the info to the RR database labeled it as such. Also, all the talkgroups are attributed to the USPS.
On another note. According to the license info on the FCC website, that particular callsign is only for one frequency pair. How can you make any kind of a TRS with one frequency pair?
Regards,
John
Tim
Milwaukee, Wi
Howdy All...
US Postal Service is using 854.7625 for their semi truck deliveries to/from the airport terminal. It is indeed a single channel LTR system (One of many in Milwaukee area). They recently moved onto here from 859.6875
Tim
