Help, for some reason I can’t get UniTrunker to work with the PRO-197. Yes I read all the post in the form and I’m still not having any luck. Since the 197 is similar as the GRE600 I figured it should work.
I tired it using the PC/IF method using the USB data cable and the CCDump was on. I’m using the older version of UT 1.0.57 (Older Version). I set UT to use Null Modem as stated on web site, no luck.
I also tried using the headphone jack and direct line-in to my sound card. Uniscope detects the audio but still no luck. I checked my sound & audio devices and everything looks fine. Should I also be showing a null/serial sound device since I installed the USB data cable?
I would prefer using the data method. I only want to use it for data and not voice. Can someone help.
Dan
Dan
