Utility Frequency Help
MTS2000des
5B2_BEE00 Czar
Most likely they've migrated to digital voice, NXDN or DMR, though the license only shows them authorized for NBFM. If they have gone digital and are NOT encrypted, a digital capable scanner such as a Uniden SDS series, will be capable of receiving them.
Boogieman77
Turtletown Tennessee
Boogieman77
So long as they are actually using DMR and not NXDN or P25, and are NOT encrypted, it will. Can you confirm what kind of radios they have?
I can try and find out.
could you post a recording of the noise ?
I will when I can catch it and be able to record it. The Rx lights up like they are talking and it kind of woom woom sound. Very hard to describe.
Vern
Union County, GA
Boogieman77
Tri-State EMC up in Fannin County is indeed 6.25 kHz NXDN digital, and is NOT encrypted. The DMR radio that you looked at on Amazon won't work with the NXDN digital. You'd need to use a scanner that is NXDN-capable (and very pricey) or get a used commercial NXDN (preferably Kenwood) that is programmed (Rx-only) for those channels. I can't send you an email as your account might be 'too new' ... If you list contact info, I'll send you additional info.
Vern
Boogieman77
Boogieman77
Tri-State EMC up in Fannin County is indeed 6.25 kHz NXDN digital, and is NOT encrypted. The DMR radio that you looked at on Amazon won't work with the NXDN digital. You'd need to use a scanner that is NXDN-capable (and very pricey) or get a used commercial NXDN (preferably Kenwood) that is programmed (Rx-only) for those channels. I'll send you a PM.
Vern
Thank you.
I added a signature and website. Let me know what I can and can't add here. I can place email in message if I won't get banned from here. Lots of forums frown on that.
Nchpiboy
Hayesville, NC
I can pick them up here across the line in Clay County NC. listed under the Rocky Top Mountain repeater in Union County Ga.
NXDN RAN 60
