UV-5R - Receive on one freq and send on another?
Ziggy925
I was wondering if it's possible to setup my UV-5R to receive on one of our club's repeaters and send to another. Not sure why, but it seems like I can hear better on one repeater but when transmitting that repeater doesn't recognize me. All settings are correct.
chief21
Western NC (Summer); Tampa Bay FL (Winter)
If you're talking about cross-band repeat, the UV5r does not have that capability.
If all the settings are REALLY correct, the only likely reasons that a repeater isn't hearing you are 1) encode tone is incorrect or not activated, or 2) out-of-range. Assuming one is needed to access the repeater in question, double-check to make SURE that you are actually transmitting a tone to the repeater. If that isn't the problem, you're probably going to need an external (or higher, or better) antenna.
John AC4JK
rsklar
North Manchester, IN
It sounds like you may have an issue with tones. But assuming you have the repeaters linked you could talk into one repeater while listening to another. Simply manually program the transmit frequency to the other repeater..
