UV-5R tone search
wsalopek
Albuquerque, NM
Can someone say whether the UV-5R's still have the tone search capability? I've seen references that the tone search was disabled in a firmware update...my radios have firmware BFB289...Here is the doc I'm looking at...page 22:
http://www.miklor.com/uv5r/pdf/uv-5r_v1.0-annotated_by_KC9HI.pdf
My problem really is that when I press SCN on the radio, nothing seems to be happening? But maybe the display is SUPPOSED to stay static? And only changes when a tone is registered?
Also...that firmware page...are all those firmwares compatible with the UV-5R?
Thanks...
nd5y
Wichita Falls, TX
If tone search works you should see it scroll thouugh the tones or DCS codes until it finds one, but it doesn't work unless a signal is present or the squelch is open.
My Baofengs are old so I don't know if the current ones still have it.
Menu 11 should be R-CTCS and Menu 10 should be R-DCS. Both have search function at least in older firmware.
To check if your radio/firmware has tone scan, go to VFO mode and enter a frequency like NOAA weather with a continuous carrier, or jus set the squelch to 0 (open).
Press [MENU] [1] [1] [MENU] [*SCAN] and see if it starts searching.
Tone search will work in memory mode but you won't be able to save or change the receive tone in an existing memory channel.
