I haven't figured out how to create a scan list let alone scan anything. What a nice little radio to have such a ****ed up manual.
The radio automatically creates a "scan list" when it is powered up or rebooted. The "scan list" is based on whether the SCAN flag of each programmed memory is set to ON (1) or OFF (0). When the SCAN flag is set to ON, the memory gets added to the "scan list". When the SCAN flag is set to OFF, the memory is not added to the "scan list" (which means it won't be scanned when scanning).
Memories that are programmed using the keypad will always have the SCAN flag set to ON. They won't be added to the "scan list" until after the radio is power cycled or rebooted. The only way the SCAN flag of a memory can be changed to OFF or set to OFF to begin with is by using software.
This is done in the...
- OEM software by editing the SCAN_ADD column: "ON" = scanned, "OFF" = skipped
- CHIRP software by editing the Skip column: " " = scanned, "S" = skipped
Scanning is initiated in MR/Channel mode or VFO/Frequency mode by pressing and holding the [*SCAN] key until scanning begins. If menu 14 (VOICE) is set to ENG, a "scanning begin" prompt will be heard.
Menu 18 (SC-REV) determines how or if scanning resumes after scanning has been stopped by a received signal.
Menu 7 (TDR) is disabled while while scanning.
Menu 1 (STEP) determines the VFO frequency change while scanning in VFO/Frequency mode.
The direction of scan can be changed by tapping the [^] and [v] arrow keys
The scan function can also be used to...
- scan for stations in Broadcast FM mode.
- scan for CTCSS tones and DCS codes.
These manuals and references should also help:
UV5R User Manuals
Reference for UV-5R Menus
UV5R Manual Programming Flow Charts
Jim KC9HI
