uv5r gmrs
K3YGX
I have one of the baofeng uv5 GMRS ht......I can't xmit on CH15 on it -- everything looks right in chirp
It just gives a beep and no signal -- my Part 90 uvr5+ can do it illegally as a test.
Do you or anyone else have this issue or a fix ??
Denton / Decatur, Texas
Both of mine work on 15. does it transmit on all other channels ? there is a transmit lock out. it will lock out uhf or vhf, or both. it's in other settings. look for uhf and vhf, un check the box.
K3YGX
All other channels work fine.
UHF was checked......unchecked it w/no result - still no xmit(it does receive) on ch 15
It beeps when keyed down but nothing -I did a reset with no results either
I guess this one's a dud.
shhhhh im both, just an old account.
im trying to confuse the fcc.
i was talking to a walmart employee, and a helicopter started flying around in a figure eight over me.
K3YGX
Thanks, guys even Baofeng says it's defective......back to figuring out my dmr ht.
K3YGX
Well, I found that a new software update (v2.0) corrected that problem and all channels
will transmit (not in vfo mode though)
