uv5ra usb cable help
kc2sgi
smithtown,ny
trying to program a baofeng uv5ra using supplied usb cable and I go to install the cable and the comp say not successfully installed. how do i get it to work
daugherh
Upstate SC
More Info Please
Can you give us some more details?
  1. What Operating System are you using and is it 32bit or 64 bit. (Right click my computer or computer and hit properties)
  2. What programming software are you using for the radio? Chrip or the Baofeng software?
  3. Have you installed the USB drivers for your cable or is that what you're referring to as failing?
along with anything else you may think we can use to help you.
Once you give us that somebody will be able to help you out a LOT faster.
