Vacant conventional frequencies for NAS?
billy2047
📶 🕨 Ø T₁ ÆS Ⱬ ⬜ ᴴ L |→| 𝅘𝅥 💾 🛰️ 🔋
SYS REG RFSD
Hi all, what conventional RX frequencies do y'all use to park on for NAS?
Asking because I'm experiencing both co and/or adjacent channel interference when weather conditions are just right, causing radio to miss traffic.
*Setting system search time to 255 doesn't really solve it, only makes it longer before radio latches back on the DX signal
BB
chrismol1
P25 TruCking!
Did that fix it? is your scan list only comprised of trunked talkgroups and the conv is only an anchor ch for the trunked scan list. if there was activity on that conventional channel holding it up from going back into active scan and locking onto the control channel. If the system search time is 255 and only 1 system in your scan list it should be on that system for 255, if no ch grant and timer expires, briefly check the conv ch and back to the system for another 255. and no activity on that conv ch it should be unnoticeable
billy2047
SYS REG RFSD
In the zone channel assignment page scroll right and change tx opt transmit dev to 2.5 khz
got it! thanks for the help!
The thing is, I live very close to a 8CALL90 (851.0125) repeater. Since 851.00625 is adjacent to 8CALL90, it sometimes causes adjacent channel interference with NAS.
I've tried using freqs higher up (>861MHz), but that makes it even worst because cell towers etc. It seems like there's really not much vacant freqs in the 800mhz band. Maybe try the 700 MHz band??:)
chrismol1
P25 TruCking!
Go to 700 sure if that will do it, I'd search FCC ULS in a decent radius around your location to make sure whichever freq is not in use
