VB-Audio Virtual Cable
RadioChief55
I use an SDS200 with the LAN for a feed, I use VB-Audio Virtual for it. I want to start using SDR-RTL for another feed that I provide on the same computer and I need to use a Virtual Cable for that to work. I can figure out a way to run 2 instances of the VB software. Anyone ever have this issue and or a solution?
Thank you
dave3825
Suffolk County NY
Pretty sure you purchase an additional cable.
I have vac (virtual audio cable) and can run 10 cables.
What software is handling the sds200 feed? What software will you use with the rtl sdr dongle?
seagravebuff60
Forensic Scanist
I have also used VB Cable and VAC, two different software programs. I like VB Cable for small tasks that require two or fewer Virtual cables and VAC for more complex tasks like Unitrunker. Both work great. I also use Voice Meter Patato with my VB Cables in a complex setup, and it works flawlessly.
I think you can purchase up to 4 VB Cables. See here: VB-Audio Virtual Apps
RadioChief55
I'm using the free version, if I purchase it, it could be used in multiple instances?
