Vertex 824 beep
Az1988
I have a vertex 824 which beeps everytime I transmit. Anyway I can disable the beep? Thanks.
MBill
Assuming the VX-824 is similar to other Vertex portables you can check the following two
menus:
"Scanning" - Should be a box where you can disable "Scan beep".
"Miscellaneous" - Should be a box where you can disable "ARTS Beep".
Maybe one of these will turn off the beep.
Do you have "bell" enabled for low battery warning? Maybe this is what is causing the beep. I think
this is under the "Power" menu.
Otherwise you may have an issue with the radio itself.
