Vertex RX battery save option
Danny37
New York City
Can anyone explain in-depth about vertex's recieve battery save options pertaining to the adjoining parameters? There's no in-depth explanation online that I could find.
In the CPS, there's options like "ABS" or "1:3" etc.
What do you believe is the best setting?
I noticed the beginning of each transmission is cut off abit. I'm in need of a battery lasting about 8-10 hours.
All I could find online is that setting is like a sleep-timer like what computers have but that's about it.
Thanks in advance.
radiotweester
Oregon
My experience with it is I'm not impressed with any of the "saver" settings. The reason is as you describe, transmission clipping.
Managing a fleet of VX-420 series (yes, a while ago) using the LiIon batteries, there was no problem lasting through 12 hour shifts. It's all dependant to how much TX you are doing and if you need high power. If you are ok with the first 1/2 second clipped (great if using mdc or dtmf in pre) I think I'd use ABS. 1:1.5/1:2/1:2.5/1:3/1:3.5/1:4 as I had it explained was on time : off time in 1 second.
Danny37
New York City
I switched the radio to ABS and it really drained the battery on my vx-451. The radio came default with the 1:7 setting and lasted nearly 20 hours. I'm going to try it on 1:1 setting and see how long it performs. I'm hoping I can get 12 hours out of it without missing a chunk of the beginning of a transmission.
