Vertex VX-P829 scan settings
fireboat61
DelMarVa
I recently purchased the VX P829 portable. I am trying to see if there are any specific scan settings to allow the radio to pick up a frequency before it drops off. When scanning I generally hear everything during a signal zone scan. The question is in "all zone scan" mode. Is there a setting that will allow me the best scan time , enough to slow down and pause on each frequency. I think it scans pretty fast right now.
SirJ
Intelligence Everywhere!
Los Angeles/Ventura County
Well you can set the scan speed as low as 1 second. Radio will never scan as fast as a scanner.
Press the assigned scan button once that's scan the zone your in based on your programming if you press the scan button again it goes into RWSAN mode to ignore a channel that be hanging due to PL issues or a unit pressing the ptt on accident you can hold the scan button and it will temp ignore that channel until you turn scan off or turn the channel knob.
