Vertex VXD 7200
Mikesuper26
Stamford, CT
Hello all,
I have a Vertex VXD-7200-G6-40 that I purchased off eBay, new old stock. I have Vertex Clone Editor version 5.5 build 34 running on Windows 10. Whenever I attempt to connect the radio to my PC using a CT-150 cable, I receive the following error in the Windows device manager:
This device cannot start. (Code 10)
{Operation Failed}
The requested operation was unsuccessful.
There is also a yellow triangle on top of the "Vertex Radio" icon. I have tried this on three Windows 10 PC's and gotten the same result each time. Any help would be appreciated.
Radio firmware: R01.07.04
CPS: 08.01.01
n3obl
ØAES-1024
PA
CT-150 not the correct cable.
you need a ct-151 for mobile radio that plugs into mic jack.
Mikesuper26
Stamford, CT
Thanks for the reply. I got it working late last night using the CT-150, which plugs into the rear 26 pin accessory connector on the radio. I had to use a virtual machine running in Virtual Box configured with Windows 7. Once the radio connected to the virtual machine the software read from and wrote to the radio without a problem. It must have been a compatibility issue.
I wanted to purchase a CT-154 which would have plugged into the mic jack, but they are no longer available.
riccom
My wife and kids said i have to many radios!
Yankton, South Dakota
Hi, know I am a bit late to the party, but if you have not figured it out yet, try running as administrator, and it may help as well, I know I had to on 10 and 11
sjcdjcliving4god
Roseburg Oregon.
Could you tell me where to get windows 7 in virtual box? I downloaded it but it won’t start. I keep getting errors when I start windows 7 in virtual box.
