I need help, I’ve search and search and can’t find any advice. Im new to all things CB so im trying to figure this all out as I go. I’m running a Stryker SR-447HPC2 with a 102” whip on a mobile setup. I can’t seem to get an SWR below 8 unless I unscrew the coax on the antenna side until the connector is loose. I’ve tested the coax with a multimeter, replaced the S239 stud and tested it with a multi meter, and I’ve tested ground continuity from battery and frame to radio, antenna mount, and even frame to coax and everything is checking out good. My only thought is maybe I need to replace the mount because the mount is a piece of 1/4” steel plate with a hole drilled through it. Thank you for any help and advice!
