Baofeng VFO & Channel Mode
Unidener
Ok.....gotta ask.....If I'm looking at a frequency on a BaoFeng and then select MR (for channel, correct?), why doesn't it switch from that frequency that you are looking at to the channel number related to that channel? For instance if I'm looking at channel 1 which I programmed in Chirp to 146.5 then I select VFO, why doesn't it display 146.5?
What am I not understanding? I've looked and I don't see a video addressing this....
Thanks!
Whiskey3JMC
DXpeditioner, RRDB & Google-fu ninja 4 hire
Philly burbs 🇺🇸
Variable-Frequency Oscillator (VFO) and Memory Mode (MR) are two entirely different modes on a receiver. The former mode being tunable meaning that when you press up or down arrow the frequency goes up or down whatever step size you have the VFO set to. Memory mode (MR) is just that, frequencies you have programmed into memory. Hope this clears things up for you
Unidener
VFO and MR (I call channel).....I wish I could hit the button and see the VFO for say channel 10 and hit the VFO button again and see channel 10s frequency.... How do I know if channel 10 is 146.5 without CHIRP? While on the channel I selected menu and went through the steps and didn't see the frequency....
