vintage ambulance radio pulse dial
jruta
Nj
Hi all, does anyone know who manufactured the rotary pulse dials for M on the old ambulance H.E.A.R. radios? Was probably for mitrek or syntor stuff. I’m guessing Moto outsourced them. Looking for a part number/model thanks
jruta
Nj
Hi and thanks for the reply. I’m not sure- it looked like an “extension” piece branded by Moto. I will take a look. Thank you!
NVAGVUP
Back in those days, Motorola mfg most stuff in-house. It may not have been part of standard package, but likely ordered as an SP. (Or a field kit installed as an SP) SP=Special Project. (At least that is what defined "SP" for us)
jruta
Nj
Gotcha. I wasn’t sure if maybe it was something from say, western electric that they adopted for use. Thank you
krokus
Southeastern Michigan
If the encoder is an actual rotary encoder, Motorola might have procured them from a phone manufacturer, then used them to build the modules.
If you have a later version, where a keypad is the input, then the electronics output the PPS, that might have been all in-house.
Once again, both of those are if it is a Motorola branded accessory. After market accessories should show their brand, somewhere.
bruch
Roanoke, VA
It seems that the M dial units (1500 hz interrupted tone) first appeared in the early 70s on the Micors, but may have been available on the Motrac/Motran series. I never saw any other brands shaped like Motorola's, GE used a different type, same function.
xmo
The rotary dial mechanism was an outsourced component but the enclosures and internal electronic were produced in-house.
jruta
Nj
It would look like this
thats what I had thought. Thank you
jruta
Nj
Great information. Thank you
xmo
Secode was another rotary dial signaling format. It used 2805Hz. It was often used by radio common carriers to alert subscribers. Secode made a nice mobile control head that had a telephone handset and could be connected to a variety of mobile transceivers.
Here is a picture of a Secode encoder next to a Reach encoder at an answering service 'back in the day'
xmo
GE and Motorola sold the Secode heads until they developed their own products. Here's one:
CCHLLM
"SECODE" is most likely what you're looking for. A lot of us old dinosaur techs are very familiar with those units on MotherMoto and GE installations. They were very reliable and gave us few if any problems unless they were subject to half-assed installation and/or lack of maintenance issues. The name comes from SEquential COding DEvice, or something close to that from the documentation I remember. Most were set up for one tone operation only, but they could be set up with an optional tone selector panel with 5 or 6 tones selectable one at a time for different encoding purposes.
xmo
In the late 60's & early 70's there was a push to make it possible for the rescue squads to talk directly to the ERs rather than through dispatch.
The H.E.A.R. system was developed to meet that need.
Typically, there were one or more 'Med' repeaters installed in an area with wireline connections to remote units in the hospitals. Because there were often several hospitals in an area, it was necessary to implement a selective calling system so the ER staff didn't have to monitor the channel.
Hence, the encoders in the squads and decoders in the remote units at the hospitals.
Here is the Motorola rotary encoder for use with Motrac radios:
NVAGVUP
I used to maintain several hospitals and dispatch centers who has rotary dialers on T1605 remotes. As noted by xmo, the systems were designed to contact individual locations, while RF shared same freq/PL. (That way ER nurses didn't have to hear conversations with other hospitals) User had to know the site location "digital dial code". User would dial individual location and that was the only site/hospital that unmuted. (Digital Dial Decoder was typically in base station) Hospitals could "dial" other hospitals also. (IE The reason the dialers were installed on remote eq)
