Vintage Receivers, Hammarlund HQ-129-X
mikethedruid
Sneedville, TN
I finished my restoration of a Hammarlund HQ-129-X. It is a highly efficient, 11 tube, superheterodyne general coverage receiver. It receives from 540 KC to 31 MC in 6 bands. Bandspread for the 80, 40, 20, and 10 meter bands is calibrated and appears on a separate dial. This is an excellent receiver for general short wave reception.
w2xq
Burlington County, NJ
Nice job. Interesting about the antenna trimmer. I don't recall that control on the 129 I owned for a few years c.1964.
I owned a -120, -129, -140, and -150. The HQ-150 was my mainstay from the mid-1950s to the late 1970s. It was a great receiver.
In 1964 I had the -129 with me in a apartment in Philadelphia while attending college. I remember hearing 50kw WBT-1110 Charlotte on + and - 25 kc. The signals were weak and it took a while before I matched them with 1110. The CE was surprised I heard the spurious signals. The signal level at the transmitter was so low their test equipment had to be recalibrate. The failure was in the crystal.
badoyster
Beautiful!
MiCon
Mike
central AZ
Very nice.
Did you do the restoration yourself? If so, would you be willing to do another one? I have a TRIO 9R-59D circa 1969. Very similar to your Hammarlund. Tube radio. It's been sitting around for over 30 years. Still works, but in need of a serious tune-up: Some tubes probably need to be replaced, could use an alignment, knobs need a good cleaning. I have no idea who might still be servicing the old radios.
mikethedruid
Sneedville, TN
I do these restorations for my own radios. In restoring the Hammarlund HQ-129-X I replaced ALL of the condensers, checked all of the resistors, replaced any that had drifted out of spec with new 1% resistors of equal or higher wattage, tested and replaced any weak or bad tubes, and did a complete alignment which is somewhat tricky because of the crystal filter, which requires the IF to be aligned to the actual crystal frequency which always varies slightly from the listed IF frequency slightly, and requires special gear to determine the frequency, or using an alternate, much more time consuming method which few techs today would know. After that I had to strip the cabinet of layers of hideous old paint applied by various owners in past years, and then re-paint the cabinet. I enjoy doing this work for myself because if worst came to worst it would only be my own property that would be screwed up, but I would not want to do this work for a stranger.
Before:
After :
As for your radio, a radio of that vintage will require all of the above to be reliable and work to its best. One might get away with replacing only the power supply filter condensers at a minimum, but that would run the risk of other condensers failing soon and causing damage to the circuitry, which is why a proper restoration requires all the above work.
