virtual radar
stuart3009
i expect this has come up servral time how do you set up virtual radar ive tried so many times one min its connecting and nothing is happening ive tested the settings and its says its connected but no plane are showing am i doing something wrong
dave3825
Suffolk County NY
I can post my settings later when I am home. In the mean time what dongle do you have and what are you using to feed Virtual Radar?
You also may find some info here
stuart3009
I’m using a sdr dongle and sdr sharp with a diamond d777 antenna
n5pwp
Spring, Texas
I never used VRS with SDRSharp. The config that works for me is dump1090 feeding VRS.VRS Dump1090 Config.PNG
n5pwp
Spring, Texas
so i guess sdr sharp what would be another bit of hardware to get
The only hardware you need is your dongle, your antenna and a PC of course ;-)
Dump1090 is free software. In looking at the other sources I used at one time I did use ADSB# which comes with SDRSharp. Is that how you are doing it or just SDRSharp feeding VRS?
n5pwp
Spring, Texas
Here's my config for ADSB#. Its been a while so I don't remember what my results were with it but I do know the most reliable method I used was Dump1090.
Notice the different port number used with ADSB#.
n5pwp
Spring, Texas
When you're brand new to something its easy to overlook things like that. Everything on the screen overwhelms you and you miss some things. VRS is a good piece of software and I have spent many happy hours with it. Enjoy, Stuart.
Mike
jazzboypro
Laval
I use an RSPDuo with SDRUno. SDRUno has an ADSB plugin that works well. i feed the signal to virtual radar. The antenna is a Diamond discone antenna.
Pape
Quebec
Dump 1090 here also but linux version from a rpie over the network
