Visiting AZ for a few days.
eagle90301
USA
I’m visiting the Phoenix area and want to listen to fire activity. I do not have a trunking scanner. Can I still listen to what is going on in the area. I want to listen primarily to west valley I hear dispatch but can not figure out what channel they go to after that.
caphab1
Mesa, AZ
Most West valley FD's are dispatched by Phx FD here:
154.19000 KOA519 BM173.8 PLPhx FD A1Fire - A1/Dispatch FMN Fire Dispatch
These are the west valley scene freqs
154.07000 KOA519 BM516 DPLPhx FD A3Fire - A3/West Phoenix FMN Fire-Tac
155.67000 KOA519 BM624 DPLPhx FD A9Fire - A9/West Phoenix FMN Fire-Tac
The rest of the A-Deck freqs are listed in the Phoenix Section here:
Heres the caveat to A Deck as its known.. these are mainly for firegrounds so you will be missing a lot of traffic as most minor accidents, Medical calls etc are handled on the RWC digital K Deck talkgroups. Im pretty sure A1 is simulcasted but once dispatched you may not hear anything else unless you purchase a Digital capable scanner for the system.
Here is a little break down of the A Deck from KB7MIB/John.
A-5 is Northeast;
A-6 is Northwest;
A-7 is Tempe;
A-8 is Downtown and South Phoenix, and Ahwatukee;
A-9 is Southwest;
A-10 is Daisy Mtn. (New River and Desert Hills areas);
A-11 is Scottsdale;
A-12 is Chandler and Sun Lakes;
A-13 is Tonopah and Harquahala Valley;
A-14 is supposed to be for Haz-Mat sector use, but I've never heard it used;
and A-15 is for car-to-car use. I think I heard a building inspection being conducted on it last year. The RDC alarm room does not have transmit or receive capability on this channel.
A-16 is the same as A-1.
A-2 is for special uses. (I once heard a bi-lingual dispatcher/tactical radio operator, or TRO, facilitate a translation when the firefighters gave a Spanish-speaking family member of a patient one of the radios, and the dispatcher asked them the questions the medics needed to tend to their patient, and then repeated the answers back in English for the medics.)
A-3 seems to be an overflow fireground channel, particularly when A-8 or A-9 are already in use. I typically have heard incidents between the Downtown area and the Maryvale area assigned to this channel. It doesn't seem to be frequently used, however.
A-4 is interoperability VFIRE-21.
Should you decide to purchase a digital here is the system you need to explore and program:
Hope this is what you need.
Preston
cellphone
Silent key.
Ahwatukee, AZ (Phoenix)
When you hear a dispatch, there will be a tactical channel assigned. If you hear "K Deck xx" then these are on the RWC Digital trunked system. If you hear "Fire Channel A xx" these are the VHF frequencies listed above. Keep in mind, the VHF channels are simplex and not repeated, so you will need to be within a couple miles of the incident to hear fireground units.
eagle90301
USA
154.19000KOA519BM173.8 PLPhx FD A1Fire - A1/DispatchFMNFire Dispatch
154.07000KOA519BM516 DPLPhx FD A3Fire - A3/West PhoenixFMNFire-Tac
155.67000KOA519BM624 DPLPhx FD A9Fire - A9/West PhoenixFMNFire-Tac
Preston
Thank you for the info. So if I’m in the west valley put those 3 channels you listed and I’d have the best luck? And put the others incase they assign another “A” channel. Is that correct.
eagle90301
USA
Thank you I’ll listen to dispatch and select the correct fire channel when needed.
KB7MIB
Peoria, AZ.
A-6, 154.3100, is the primary fireground channel for the Northwest Valley. This is roughly west of I-17 and north of Northern Ave.
A-9, 155.6700, is the primary fireground channel for the Southwest Valley. This is south of Northern Ave.
Let me see if I can find the older thread that has the channel boundary maps.
Edit: I found the older thread. The first reply by me has a link to an old A-deck channel assignment map. It'll still give you a good idea of where the boundaries are. A-3 assignments typically seem to overlap A-8 in the area west of Downtown Phoenix into the Maryvale area of West Phoenix.
If one incident is already working on the primary channel, and a second incident needs a channel assignment in the same area, a secondary channel will then be assigned for the second incident. It would be a good idea to have all of the VHF-High channels programmed in.
Be aware that the vast majority of calls are medical in nature. Other than the dispatch channel, there may be little activity for you to listen to, since, with few exceptions, the vast majority of calls will be assigned to a K-deck talkgroup on the RWC trunked system. And you'll have to be within a few miles of an incident to hear anything other than the alarm room tactical channel operator.
John
Peoria
eagle90301
USA
thank you John. I’m at my parents who live in Peoria. WOW I’m amazed at how busy their dispatch is. My father has always been a fire buff and that’s where I get it from. He’s been trying to figure it out for a little now. I found all the “A” deck channels, and put them into my scanner. Hope I hear something other than dispatch while I’m here.
caphab1
Mesa, AZ
PFRD dispatches for a multitude of agencies thus why Cranky Betty is always going.
Unless you're near the scene, normally with in about a mile, you may or may not, or as I shared before, KDeck is your friend here, and unfortunately that requires certain equipment. I also just realized, although its the unconventional manner, that you could listen to KDeck on Broadcastify if you so desired. I am an east valley guy so I apologize for giving you A3 not the more active A6.
