That scanner is particularly prone to front end overload. You will get a strong signal on the meter but hear next to nothing. Might try the attenuate feature and if you have an outside antenna, switch to a DUCK or telescoping antenna. I had that problem with the State Police in this state. With an outside antenna, nothing, back of set radio shack cheapo....problem solved. Good luck.
Eugene KG4AVE
