Volume button brightness control
Peerlessk
Lima NY
Decided to get myself another sds200 . They keypad is definitely brighter . anyone else notice the newer sds200 keys being brighter . Also if I click the volume button 3 times it toggle low medium and high then goes dark . my first sds200 doesn’t do this , normal if not what’s the settings so it will do that ? I tried setting my first sds200 to do what the new one does pertaining to the volume button controlling the screen brightness . Thoughts?
jonwienke
More Info Coming Soon!
VA
The low/medium/high presets in Display Settings probably aren't the same.
jonwienke
VA
If all the presets are set to the same brightness, that's what will happen. Did you check that?
jonwienke
VA
If you're absolutely sure both units are programmed identically, the the one may have a defective clicker switch on the volume encoder.
werinshades
Chicago , IL
In Sentinel/Edit Profile/Display Options...lower right corner...Dimmers (change default settings): I have mine set: Low (10%)..Medium (40%)...High (100%). I'm not sure if you were on the same page as jon?
Peerlessk
Lima NY
Yeah same firmware . I’m thinking the volume button is faulty. The new ads200 has click to the volume Button where as the first sds200 pushes in but doesn’t click . If this makes sense . Thing is I never knew I didn’t until the new sds200 arrived . The first one has been in the same place since out of box . No falls no access to those to mess with it . Thanks for the reply’s . I’ll call Uniden get a new volume knob
kruser
Well Known Member
W St Louis Cnty, MO
Yep, you should be able to feel a physical click or snap when pushing the volume control in. You should also hear it so it sounds like your first 200 does have a bad control.
TailGator911
Silent Key/KF4ANC
Fairborn, OH
Both of mine change low-med-high with volume button click, but the numerical keypads stay the same (both are very visible in low light conditions). The optional settings only affect the display screen brightness.
Peerlessk
Lima NY
So.... playing with the volume button and turning all the way up . I get the clicks and the three setting low,medium and high . Lol now I’m really confused
jonwienke
VA
If the display brightness only changes when the volume control is all the way up, you have a bad volume encoder.
