Volusia County EDACS problems (?)
cal680
Edgewater florida
All of a sudden all I hear is chopping radio transmissions. Some are clear and then the responce is chopping. Allot of open key ups without voice. Have they totaly changed the frequ or control channels? Some sound like they are scrambled. I see in the channel list they have alternate control channels listed. Do those need to be put into scanner and if so, where?
Reconrider
Inside the Galaxy
Radio Galaxy
No body will have any idea of what you’re talking about unless you link the system you’re referring to
cal680
Edgewater florida
Yep, screwed that one up. When I originaly started here it was only for local county radio system. Not all over country. sorry about that. Refering to Volusia County Florida 800 meg trunked EDAC system. It seems to be OK now. Working normal. Must have been problem at tower. Thanks and please disregard any fuirther.
cal680
Edgewater florida
Volusia county 800 EDAC. Did they change the control channel within the last week? Radio is all scratchy, choppy. Some channels have a beeping sound like it is not in the control channel. I cleared the radio and reinstalled all freq in case was radio problem, but still the same. Freq list says the control channel is LCN 14 845.3625, but the control channel is showing on LCN 6 860.4875. I live within 3 miles of the antenna by the way the crow flies.
u2brent
OAMPT
KRWDPAXKRS1
maybe something to do with this newer system coming online?
Perhaps the EDACS is on it's way out.
Latest News Update Posted on 2021-09-03 12:56:09
The Volusia EDACS and P25 systems are still in flux. The previously transitioned EDACS site 20 (Daytona Beach) was moved to the P25 system a few weeks ago and has now been moved back to the EDACS system. As the P25 system comes online in the coming months, listeners should be aware that sites and frequencies could change.
Discussion seems ongoing in this thread
tvengr
Well Known Member
Baltimore County, MD
I suggest you click on Report and ask that your thread be moved to the Florida forum. There will be members in your area who can better answer that question.
u2brent
OAMPT
KRWDPAXKRS1
FYI,
All frequencies must be included on an EDACS system, not just the CC. The scanner needs the correct LCN's & frequencies to trunk track, unlike P25 which can be followed with just a CC.
lwvmobile
DSD-FME
If you are hearing a beeping sound on the tail end, then that is certainly a voice channel LCN. EDACS has a distinct dotting sequence at the end of all non control channel transmissions. My understanding is that its supposed to help prevent normal scanners from picking up voice channels by dotting and keeping the scanner from landing on the real active voice channel and make it difficult to follow.
EDACS also rotates control channels, so you'll certainly need to know all associated frequencies for an EDACS system or site. Not sure if the Volusia County EDACS system works the same as SLERS exactly, but where I live, Site 243 constantly rotates between LCN 1 and LCN 2 as Control, and occassionally even jumps to LCN 3 as a control channel, so its fair to say that at any time any LCN can become the control channel.
edweirdFL
Daytona Beach, FL
FYI 856.9875 is the current control channel for the East System. It's been sounding OK on the feed I provide when ever I have listened, which is almost always for some period each day.
mike341
KISSIMMEE, FL
Hello. Im monitoring there control channels on my SDR sharp freq. 858.4875, sometimes 857.7125. Hope this helps, Mike
mike341
KISSIMMEE, FL
Im having issue when running unitrunker. it picks up that f-858.4875 narrow band step 12.5 band with 12.5
batdude
Florida Db Admin / Florida Forum Moderator
Moderator
East Central, Florida
please continue this discussion in the master Volusia thread:
